Help! My intermittent start failures
#71
RE: Help! Sleepwalker! My intermittent start failures- S320
As a matter of fact, my unit has an OVP relay
the dealer had just replaced a unit for another 1995 C280 who did has the same symptoms as mine. That car has not returned for a complaint for 3 weeks but I am not sure whether the OVP relay replacement did solve the problem.
Well, I hope this attempt will make a difference..
#72
if yours got an OVP, then it's worth a try.
the part is relatively not expensive. you can use it for test purpose or simply replace them.
#73
well the ovp replacement did not solve the trick, the damn problem happened again two days later after installation.
Now they are trying to replace a new wiring harness, that's the final solution.
The wiring harness is the CAN Bus controller right? This harness does the transfers of signals from the IFZ to the HFM right?
#74
yes. the CAN BUS goes by wire.
but i still stick to the version where the problem only happens after the engine control unit was replaced.
#75
Thank you for your reply sleepwalker,
Somehow I agree with you that it may not be necessasry to replace the existing wiring harness.
But it is still part of the process of elimination and I would not take the risk of applying this replacement.
I hope you agree that my case is a question of the DAS signals from the IFZ to the ECU being interrupted intermittently.
I guess i shall be requesting the dealer to release my car ASAP as this is getting nowhere and causing a big hole in my wallet.
*What are the symptoms of a failing wiring harness anyway?
#76
Hey sleepwalker,
If a failing alternator that does not charge on a regular basis when all components (highlights, fog lights, stereo full blast & air con etc) are switched on, does it affect the transfer of signals from the IFZ to the ECU?
Refer to the attachment, have you seen this equipement before?
[IMG]local://upfiles/3076/36E59C445FA645B4BFB853E8B1B4C483.jpg[/IMG]
#77
no, it will not affect not unless the voltage goes below 8 volts.
all systems are design to function between 8 and 14 volts.
if power is low, the car will stall which is a clear sign of low voltage.
i haven't seen that gadget before, but i gues it is for battery and charging test with the engine off and running.
#78
Dear Sleepwalker,
Here’s a million dollar question for all MB Vehicles owners as of 1995!
Is it possible to replace the fitted interior rear view mirror (with the red & green lens) and bypass any infrared keys or features to operate your car?
What I mean is I want to lock, unlock and start the car the classic way, going to the doorknob and insert your key. Like most Japanese cars are…
I don’t even care if people ask why I am doing this!
I am in a deadly trance/ phobia of looking at the red & green lights flashing!
Can’t sleep, eat and work……
#79
[sm=interesting.gif][sm=goodidea.gif]
let me think about that and study the system first and which is the best substitute.[sm=smiley14.gif]
[sm=smiley24.gif] it's never been done but there is possibilty.
i will answer that next week[sm=nxsmile.gif]
