Help fixing 300D odometer
Old Jun 20, 2008 | 02:16 PM
mattg's Avatar
Default Help fixing 300D odometer
I just purchased a 1981 300D with a non-functional odometer (the speedometer works fine).Doesanyone have thoughts re: howdifficult it is going to be to repair/replace the failed unit? Isthe odometerpart of the speedometer or a separate instrument; are there replacements available outside of junk yards; etc.?Thanks!
Old Jun 20, 2008 | 02:37 PM
BLUETEAM's Avatar
Default RE: Help fixing 300D odometer
The speedo head can be removed from the cluster & sent out for repairs. Check w/ local repair shops to locate repair facility.
Old Jun 21, 2008 | 11:30 PM
will3hawks's Avatar
Call North
hollywood Speedometer
Old Jun 22, 2008 | 01:01 AM
Shan's Avatar
If you take out the speedometer from the instrument cluster and remove the back cover, you will see a gear running from the speedo to the odometer.
At the odometer gear cluster, this gear extension turns an unmarked gear (all the other gears carry numbers to record the distance travelled).
This unmarked gear should not rotate freely on the common spindle(metal rod) for the gears for the odometer to function properly. But due to wear, it gets loose.
Just use a drop of locktight to secure this gear to the spindle so that it does not turn freely.
I used epoxy glue in my W123and it has been working fine for the last 5 years or so.
Shan.
harvinder25
Feb 2, 2008 03:04 PM
harvinder25
imcgarvie
Jan 22, 2008 11:50 PM
Brndnb02
Oct 4, 2007 08:14 AM
reddog6142
Dec 21, 2006 04:03 PM
