Help with CL500 ABC leak
Hi all,
I have a 00 CL500 and the ABC light comes on. First its the gray one , then the red one and then back to gray. None of the levels leak down at night but the car does bounce around while driving. Upon inspection, I noticed a leak somewhere around the resivoir or around the pressure line no shocks leaking. THe fluid level is about 1/2 inch below the cold line on the ABC dipstick. Could the low level cause the light to come on?? Where is a common place for these to leak? If it is leaking around the lines that connect to the ps pump can I just put in new Crush (brass) washers to stop it? The power steering pump looks totally dry, where do they normally leak? Will a dirty ABC pump filter cause a Light??
Any help would be appreciated.
Thanks,
Scott
Thanks,
Scott
