Heater @ a/c unit
well i was having trouble with my radio , so i pulled the center consul apart to get to the radio , while doing this task i was forced to unplug the heater/ac unit. (it worked previously) now that i put it all back together that unit does not work , does not even light up. would it be possible that i plugged in the wrong plug back into this unit? or maybe blew a fuse
? if a fuse , if someone could tell me where it is , i would make you my bff. or maybe something i missed something that needs plugged in to make this work? just need some help and ideas. edit: whoops , 2002 s430 |
Im pretty sure i blew the fuse , however i cant find its location? i have looked for days. i even tried the net , but still no luck. it sucks when my windows fog up. so im in desperate need of this fuse location , please
Originally Posted by zerocool
(Post 166084)
do you have the fuse chart that came with the car? its usually tucked into the spare tire tools. |
Tried the batt , didnt work.The heat/ac unit does not show any numbers , no illumination , I got nothing. it worked before i started messing with the radio , so what erred this unit was my mishap. I can only see 1 hook up for wires on this unit. maybe i missing something? or possibly i have un-hooked other wires by mistake? I do not know , i def want to avoid the dealership. So im open to any ideas? I dont think its getting any power? there are 2 electrical plugs in that area , they both fit. I went back and tried the other one , and still no luck.
