gas leak and surge when driving 300 e wag
hi have a gas leak and it looks as if it is comming from the cylinder (white?) just befor the tank. Second problem is two fold car will stop running intemittenly while idealing. and when driving it does not want to
go through gear change, it is running very high rpms and does not gear up it is as if it is in a lower gear and won't shift if I drop it in neautral it will than go to the right rpm . sometimes as i drive if going 40 i am indicating 5000 6000 rpm it just sounds like it is reving to high and is. again 1989 300 e automatic wagon 166,000 miles thanks
