G320 or G350
Old Aug 29, 2011 | 03:48 AM
Shibkaz's Avatar
Unhappy G320 or G350
Hi, i have recently bought a 1982 chaisses of G280, i was thinking of transforming the chaisses into a fully loaded G class of a newer model i.e 2006 to 2008.
i am stuck between which engine to install as i am concerned about fuel efficiency and power taking into consideration the heavy weight of the G wagon.
I have also looked up the CDI engines, however given the quality of diesel in where i reside it will be rather problematic to install such advanced engine.
I am in great need for an expert advice with regards to:
Which is better engine and less complicated which less fuel consumption is it the 320 or 350?
will this transformation work fine on an old chaises noting that i will change everything expect the chaisses, i.e i will mount a new/used wagon on to the existing chaisses.
your feed back will be highly appreciated, and i hope you accept me as a new member on your great forum.
aznwrx04
Jun 20, 2015 01:33 AM
treydub
May 17, 2006 03:14 PM
cairo668
May 17, 2006 03:09 PM
treydub
Nov 25, 2004 02:22 AM
madkap
Apr 27, 2004 04:57 PM
