Footbrake problem on W203 C220 CDI 2002
Old Aug 28, 2010 | 09:40 AM
chrisradioman's Avatar
Talking Footbrake problem on W203 C220 CDI 2002
Hi all, I've got a problem with my footbrake or parking brake on my C220 CDI
The car is a W203 model 2002 It works on the brake the problem is when I release it it won't come up I need to pull it with my foot.
Old Aug 28, 2010 | 04:12 PM
waybomb's Avatar
Probably a couple of things. The mechanism at the rear wheel is probably frozen up from rust. As a result, the cable came off the adjusting mechanism under the rear seat.
I had the same problem on my 97 202. Had to disassemble the parking brakes on both sides, and spray PB Blaster, along with two channel locks, a drift, and hammer to get all the pivots to pivot again, then used a file to remove all the rust on the pad spreader parts, sanded with sand paper, and coated with white grease, along with the adjusters.
Then, under the rear seat, studied the mechanism, and reset it. Pretty ingenious design work there MB engineers. Got it all hooked back up, reassembled the parking brakes, adjusted through the wheel bolt hole and then told my wife she needs to use the parking brake every time she parks, or I'm cutting her off. Well, not really, but it was a good 2-3hour job to get everything freed up and working as it should.
Old Aug 31, 2010 | 06:02 PM
Talking
Cheers for the reply, after stripping out the whole pedal assy & finding nothing wrong a friend sudgested I look under the rear seat, I adjusted the mech & now it works a treat.
Old Aug 31, 2010 | 06:56 PM
waybomb's Avatar
Does the parking brake work? That mechanism is self adjusting, and after studying it, the only way it wouldn't work is if one or both sides' parking brake application levers in the drum were frozen.
Old Sep 3, 2010 | 07:39 AM
Talking
Both brakes work a treat, they are rear discs on mine
haythame78
Oct 8, 2012 09:27 AM
Nivan
Jul 31, 2012 05:36 AM
mikeday90
May 26, 2012 09:54 AM
Duke987
Jan 5, 2012 08:59 AM
don
Mar 12, 2005 01:30 AM
