a few question 190E
![Arrow](https://mercedesforum.com/forum/images/icons/icon2.gif)
I just had to fix a fuel pump on my 190E, 1989. I wasn't geting any Voteage to it, what I found is a Relay that to me is missing the book say it #R4 it the 3 rd small relay to the right it been replace with a wire with a inline fuse before the car came to me. I need to know if I should put a relay back in there if so what relay belong there ?
also the power windows don't work at all only the driver window work. the front window on the passnger side have a borken gear and the motor and the gear been remove this was done befoe I got the car. but none of the back window work at there is voteage back there ?
and last one the trans slip going in high it slip then will go right in then a it will do the same thing again then it hold fine, it don't slip all the time only one time it will and the next it won't. I fush the trans with sea foam trans fush put max life trans fuild in it but did not replace the filter. The trans control cable was way out ajustmemt it now ajusted right but I woud like to replace it but can't see how to get it off the trans ?
cashcrazy
04-10-2005 06:37 PM
