Error Code P0455
Old 08-24-2004 | 11:55 PM
1stmb's Avatar
Default Error Code P0455
I have a 1998 C230.
My emissions report shows the error code P0455.
I have looked up the explanation and found the following explanation.
EVAP Emission Contr.Sys.(Gross Leak) Leak Detected
Can anyone offer any help of where I should be looking to address this?
Any other tips or suggestions are appreciated also.
Thank You
Old 08-25-2004 | 04:16 AM
sleepwalker's Avatar
Default RE: Error Code P0455
the regenaration valve must be open all the time.
listen if there is a hissing sound from it.
normal operation if there is regular click click sound.
feel if the vacuum is regulated.
follow and check if the line was disconnected.
the function of this is to return the fuel vapor of the tank to the intake manifold instead of disposing on the atmosphere.
Old 11-02-2004 | 02:57 AM
mbmaster's Avatar
PO455 CODE IS IT MINOR OR MAJOR LEAK?
MAJOR LEAK ... GAS CAP LOOSE OR LINE ARE LEAKING
MINOR LEAK... SHOT OFF VALVE IN THE CHARCOAL CANISTER IS LEAKING
OR PURGE VALVE IS FAULTY
Old 11-02-2004 | 03:32 AM
nagawa mo na yung na mention ko?
Old 11-02-2004 | 03:35 AM
mbmaster's Avatar
OO NAMAN
Old 11-02-2004 | 04:20 AM
i don't think so.
check component B4/3 ( fuel tank pressure sensor).
check the actual value. fuel tank pressure difference: 12.35 hPa. specified value should be -33...-35 hPa. if yes or no, tell me for the next step.
test voltage supply of fuel tank pressure sensor. voltage: 4.7....5.3 volt. if yes or no, tell me for the next step.
check component Y58/1 (purge control valve).
since you said you have tested it, heres what the test should be:
*actuation of component Y58/1
**test current consumption of component Y58/1
***perform mechanical inspection of component Y58/1
the detailed test programs are available if you want.
Old 11-02-2004 | 06:49 PM
mbmaster's Avatar
IF ITS THE FUEL TANK PRESUR SENSOR IT WILL THROW A CODE
A DIFFRENT CODE FUEL TANK PREASUR SENSOR IE INTEGRATED WITH THE
FUEL SENDING UNIT WICH IS COMPLETLY DIFFERENT DTC FROM PO455
Old 11-02-2004 | 11:12 PM
i know what you mean, it will give the FAULT CODE P0451, P0452, P0453.
did you know that P0455 was modified to "major leak in purge system, hose in system not connected or cap open"?
if we are doing the diagnosis, we should not leave anything unattended. the computer can only tell you the malfunction that it sense through pre-programmed datas... but it doesn't know the real problem.
the rest all depends on you.
the computer cannot use us to find the problem, but we use the computer to find the problem.
you are in full control, and you will use all six senses you got in order to know something.
doing diagnosis is not a job at all, but a plaything where you can have fun... similar to a kid discovering new things that amazes them. this is for as long as you now what you are doing.
cheers.
jajjrr12
04-09-2012 10:54 PM
fastedy1
12-16-2011 08:39 AM
jscott8886
11-12-2011 04:51 PM
01Benzys430
05-05-2009 11:00 PM
blackstarr777
09-07-2007 01:17 PM
