Electric steering wheel
Old Oct 21, 2007 | 04:42 PM
meersy's Avatar
Default Electric steering wheel
Can anyone help please?
Having problems with my electric steering wheel, it no longer moves up and down but can hear the motor running, is it a self fix or garage repair?
Old Oct 22, 2007 | 12:42 AM
snanceki's Avatar
Default RE: Electric steering wheel
Two motors Up/Down and In/Out. Problem with both or just the one? If both your problem doesn't appear IMHO plausible.
If one motor operates OK and the other runs but does not give the required movement either
a. the motor has become loose and the gearwheel is not engaging (unlikely but possible).
b. The motor gear wheel teeth are stripped or gear loose (unlikely)
c. The steer column assembly rack teeth have stripped (very unlikely).
Not sure if you can get motor separate from the column.
Strange failure. Are you sure both motors are running?
Note:
Access is difficult / restricted.
Removal is time consuming.and tricky although relatively straight forward if you are a skilled DIY'er.
A dealer is likely to charge an arm and a leg if they replace the column. Parts and labour.
Good Luck,
Stuart
Old Oct 22, 2007 | 03:03 AM
NAZ's Avatar
NAZ
SOUNDS LIKE HALL SENSOR WORN OR ITS EMERGENCY MODE,BEST WAY ROUND IT IS DISCONNECT BATTERY FOR FEW MINUTES RECONNECT TRY OPREATE IT SHOULD WORK IF NOT MAY REQURE HALL SENSOR....LET ME HOW U GET ON ....
Old Feb 9, 2008 | 07:01 AM
jwrape's Avatar
I have the same exact issue with my column on my 01' C320 Won't go up or down but can hear the motor running.
Old Feb 21, 2008 | 10:27 PM
mbtech17's Avatar
theres a small plastic shaft that connects the motor to the gears-they have splines on the inside its basically a miniature driveshaft-i have had acouple of these brake in half mostly on E-class 211 chassis-im a certified mercedes technician and they are horrible to replace-if you can pull your drivers underdash panel down or steering column trim panels and look inside youll probably find a bunch of small white shavings and if you can see that then theres your problem-hopei have helped out
Old Feb 27, 2008 | 01:00 PM
jwrape's Avatar
That's good to know. I will check that out. Thanks for the info.
AMGMercedes
Apr 2, 2007 10:49 PM
EP steering
Mercedes A Class
Dec 7, 2006 11:09 PM
bdg6311
May 24, 2006 09:49 AM
pen_man
Jan 26, 2004 11:55 PM
jplummer
Nov 13, 2003 05:53 PM
