E320CDi Heater problems
Old Oct 11, 2007 | 03:37 PM
Brian4890's Avatar
Default E320CDi Heater problems
Hi I have a E320CDI where the heater has stopped working. It is a 2004 Elegance with 40,000mls and up to now has been fine. The air con seems to work fine, as does the fan, the coolant levels are ok but the car produces no heat although it will still cool the car with the air con. The automatic blowers are ok and also seem to work fine. Any help on what the cause of this fault could be would be appreciated
Old Oct 11, 2007 | 03:49 PM
chassis221's Avatar
Default RE: E320CDi Heater problems
you need at heater switch over valve under the windshield wiper assembly
Old Oct 18, 2007 | 03:08 AM
mbzex's Avatar
Hello, there is a heater control valve near the cowl that goes bad VERY often.. The wiper motor has to come out and the cowling near the lower windshield has to come out. It is under there.
Old Oct 18, 2007 | 12:46 PM
Brian4890's Avatar
[align=left]Hi,
Thanks for the replies. I've had a look at the area that you are describing and think that I can see the control valve that you are referring to. It seems to embedded in the bulkhead and I'm not sure how to remove it. I can see 4 pipes going into the valve, 2 held on with spring clips and 2 with what seems like a retaining plate. Q. Are two of the pipes part of the air-con system? If I remove these pipes, can I remove the valve from within the engine bay or do I need to strip out the underside of the dashboard and get to it from inside the car? I think that if it's the latter, it will be too big a job for me.
Your help is appreciated.
Brian
[/align]
LUCKYBOY
Dec 29, 2010 02:57 PM
ben1364
Jul 31, 2005 03:16 PM
sexykatie
Feb 2, 2005 03:06 AM
05 E320 CDI
Jul 15, 2004 10:27 PM
reisszi
Apr 28, 2004 04:34 AM
