E320 Quits running
Old Sep 22, 2008 | 07:07 AM
altimatebenz's Avatar
Default E320 Quits running
I have an E320 1999, after about 2 minutes it quits running, leave it sit 5 minutes it will restart and run all day. No service engine light comes on. Does it every day. Help
Old Sep 22, 2008 | 07:13 AM
Default RE: E320 Quits running
I have an E320 1999, after about 2 minutes it quits running, leave it sit 5 minutes it will restate and run all day. no service engine light comes on. Does it every day. Help
Old Sep 22, 2008 | 11:52 PM
MBTECHINFO's Avatar
CHANCES ARE THAT IT IS PROBABLY A CRANKSHAFT POSITION SENSOR. THERE ARE TYPICALLY TWO THINGS WHICH CAN CAUSE THIS. THE K40 RELAY MODULE AND THE CRANK SENSOR. I HAVE NEVER HAD A FUEL PUMP FAIL ON A 210 CHASIS SO I DOUBT ANY PROBLEMS WITH IT. DUE TO THE AGE OF THE VEHICLE, I WOULD REPLACE BOTH THE RELAY AND THE SENSOR. IF YOU WANT TO TEST THE CRANK SENSOR, REMOVE IT AND HEAT IT UP AND TEST CONTINUITY ACROSS THE PINS. SHOULD BE 1.1K-1.2K OHMS IN A COLD/AMBIENT TEMP CONDITION. AS IT HEATS UP, RESISTANCE WILL RISE, SHOULD STAY PROBABLY UNDER 5K OHMS. ANYTHING OVER 20K OHMS IS PRETTY MUCH AN OPEN CIRCUIT. THE K40 CAN BE REMOVED WITH THE WIRING CONNECTED AND WITH THE CAR RUNNING OR IN POSITION 2, ROTATE THE RELAY AND ROLL IT AROUND IN YOUR HAND. IF YOU HEAR CLICKING, ENGINE STALLING, OR THE AUX FAN CYCLING ON/OFF, THIS IS FAULTY. ABOUT $120 FOR K40 AND $160 FOR CRANK SENSOR (FROM DEALER)
Old Oct 6, 2008 | 06:42 PM
MB Tech, You were right on with the crankshaft position sensor. So far it has worked perfectly and was an easy installation. Thanks
greek48
Dec 1, 2015 09:34 AM
greek48
Jun 3, 2015 06:17 PM
pmcd404
Jun 7, 2009 02:22 AM
mulberrystreet
May 3, 2007 06:17 PM
maineguy
Oct 25, 2004 06:49 AM
