direct ignition vs.....
I got an engine 3.2 from 95 E300 compete with fuel injection unit and intake and exhoust manifold and Direct Ignition but my car is a 1993 300se with regularIgnition system of Rotor andDist. cap.
Ineed to switch the engines (CAM broke and piston bent the Valves) not sure how bad I damaged the Pistons. obviously wiring harness is not same, I am trying to see if I can upgrade the car with this new Ignition system since all the sensors already are on the engine and the head has the1Coils per two plugs. that would save a lot onfuturetune ups.
Any thoughtswould greatly appriciated, Iknowthere is a kit for upgrading Ferrari's but not sure ifthere is anything out I could use. I think I need theProcessing Unit to this . Idonot think I can do anything with computer of this car!.
thank you again.
thank you again.
Myran
Dec 6, 2018 03:17 PM
jonthecarguy
May 11, 2008 10:33 PM
