Dash lights 380SEL
Old Sep 26, 2005 | 01:19 PM
Proof43's Avatar
Default Dash lights 380SEL
The lights just won't function. Any real clues on the cause?
Old Sep 26, 2005 | 07:08 PM
C280 wizard's Avatar
Default RE: Dash lights 380SEL
have you tried to replace them? did you check the fuse, the light switch, the reostate? these all could be the problem or part of the problem. I would go to the fuse and the switch first, and see if they are getting current could be a bad ground.
Old Sep 27, 2005 | 01:34 AM
dondas's Avatar
Try turning the dimmer **** on the dash, just below the speedo. LH **** I think. Sometimes the oxidise, but sometimes they break too.
Old Sep 27, 2005 | 09:57 AM
Proof43's Avatar
OK Guys you've given me some help. Any clues on how to clean the switch? I'm real new in the Mercedes game and know very little about maintainence. I messed with the switch and the lights came on but touching the reostat kills the lights again.
Old Sep 27, 2005 | 10:24 AM
dondas's Avatar
If you can pull the cluster out, use an electronic contact cleaner on the rheostat.
mab
Nov 6, 2008 01:01 PM
michaelesh
Mar 11, 2006 12:35 AM
dr.john
Aug 26, 2005 07:41 PM
Guitar Factory
Dec 26, 2004 12:52 AM
benz-vettes
Mar 25, 2004 11:05 PM
