coolig fans 98 300E
The two electric fans on my 300e are not comming on. The left fan will occasionally run at verry low RPM, not temp related.
Eng temp staying at 80c +- 10deg.
AC on or off eng hot or cold no change.
All fuses are good.
no codes,
All fuses are good.
no codes,
I did check the tep sensor for the gauge. But if there is an additional one for the fans I need to know the location? I was under the impression the fan should be on whenever the AC is on.
Thanks for the help. H
dlmoore75
Mar 4, 2011 07:25 AM
