CLK CONVERTABLE WON'T FOLD... PLEASE HELP!!!
HI, PLEASE ADVISE WHAT I CAN DO TO OPEN MY W208 CONVERTABLE CAUSE
THE SENSOR IN THE TRUNK WAS TAKEN OFF AND I CAN NOT OPEN IT. IS THERE ANY OPTION BESIDES HAVING TO CHANGE MY LOCKS. IS THERE A WAY TO TRICK THE COMPUTER?
RE: CLK CONVERTABLE WON'T FOLD... PLEASE HELP!!!
The top is electic? So it might be the switch, does the motor run when the top down switch is pushed? As far as the sensor beng removed? Why? You could try an trick I learned on my 88 C280, disconnect the negative ground cable for 30 minutes and then reconnect, that will default the ECU, but without the sensor, I don't know? I assume the sensor is for the top? and not the trunk, you weren't clear about that?
