-   -   Clk 320 Cabriolet Trans fluid (https://mercedesforum.com/forum/general-tech-5/clk-320-cabriolet-trans-fluid-48050/)
Alliycat May 7, 2011 11:31 AM
The trans acts like it may be low on fluid, and the manual says take it to the dealer to have it checked. Right! Like I want to spend $200 to have them put 3 buck worth of oil in the tranny. I found what appears to be the fill pipe, at the left, rear of the engine. It has a cap with "Factory only" or something to that effect on it. Is this the filler pipe? Also, is there a fluid level plug on the transmission case, or does the factory man just run a wire gage down the filler pipe? Any help will certainly be appreciated.
Alliycat May 8, 2011 08:43 AM
Originally Posted by ForcedInduction (Post 149480)
Thanks so much. Now for the next question that I should have included in my original post: What type fluid does it take? Dexron, Type F, or ?????:o
Alliycat May 9, 2011 10:27 AM
Thanks for your help ForcedInduction. We'll get the ATF changed ASAP.
