Climate Control unit
Old Dec 13, 2004 | 02:30 PM
fiminod's Avatar
Default Climate Control unit
I get no response from any of the functions/buttons on the climate control unit. Did a search, didn't reveal anything. 1987 E300TDT, only 237,000 miles (you'd think these components would last!) Is there a way to check the unit before I purchase a new/rebuilt/used unit to verify the problem? Thanks.
Old Dec 13, 2004 | 05:08 PM
Randy's Avatar
Default RE: Climate Control unit
I bit the bullet and got a rebuilt unit from George Murphy.
You can check fuses, etc. and check the aux coolant pump for being stuck.
I will check Alldata for a test procedure.
Old Dec 13, 2004 | 05:14 PM
Randy's Avatar
Is it just the blower doesn't come on for any function, or nothing at all happens? Often the blower coming on is the only noticible indication the control system is responding; you may have a bad blower motor or blower control.
Old Dec 13, 2004 | 06:36 PM
fiminod's Avatar
Nothing happens, no defrost, vent directtion change, A/C, fan speed, nothing.
Old Dec 13, 2004 | 11:11 PM
sleepwalker's Avatar
you better bit the bullet too.
seems the AC pushbutton module gone kaputz.
Old Dec 21, 2004 | 01:15 PM
Randy's Avatar
I agree; this can be caused by a bad (stuck) auxiliary coolant pump which draws too much current and fries the circuits in the control.
rlteotico
Apr 7, 2013 10:33 AM
RE320
Aug 14, 2006 11:40 PM
limey300sl
Jun 30, 2006 10:59 AM
renozuken
Dec 23, 2004 01:00 PM
renozuken
Dec 23, 2004 12:59 PM
