Changing Time on Clock
Old Mar 15, 2007 | 01:27 PM
shaolin_us's Avatar
Default Changing Time on Clock
How do you do this on a 2004 CLK?
Old Mar 15, 2007 | 04:36 PM
RJc230's Avatar
Default RE: Changing Time on Clock
I just saw this post and I apologize for my other post as I didn't know you were serious.[]I really am sorry. K, here we go...
turn the car on until you can access the menu's through your steering wheel controls. Scroll through the menu until you get to the reset settings main menu. from there, page through until you either see clock or time/date and select that. Once that submenu opens up just adjust your time in there. It'll probably ask if you want to use the 12 or 24 hour clock again so just select whichever you prefer then hit the main menu buttons again and it should back you out to the reset settings menu. To double check that it took just turn your car off take out the key then restart it. If it doesn't work let me know and I'll go through mine and make sure I didn't miss something.
Old Nov 4, 2007 | 08:20 PM
jaqo's Avatar
Hello, I got a problem setting up the clock myself. Wen i switch to time menu ther is no option to set the clock or minutes as its written in the user manual. There is the 12/24h format but no clock settin be4 that step. Any advice ?
Old Jun 12, 2008 | 11:21 AM
gastockman's Avatar
I'm sure by now you've got it figured out. For others who need this info:
I have an 03 Benz w/ GPS Navigation and the clock's time setting is adjusted through the navigation system as follows:
1. Put key in ignition.
2. Turn key to turn on navigation system and wait for it to power up.
3. Press "SVC" button.
4. Go to "System Settings"
5. Go to "Settings"
6. Go to "Date/Time..."
7. Make your adjustments.
jknorst
Jul 25, 2011 09:53 PM
malcolmparis
Nov 15, 2010 09:13 AM
rmj51156
Nov 17, 2008 07:58 PM
gizmo
May 27, 2008 05:34 PM
lpw611
Mar 21, 2005 05:51 PM
