A/C Recharge
i know you can find it. i was getting on a deep thought there must be something else.
with all those 12 pistons fitted inside your engine block, i bet there's little space left under the hood for other things.
Well. I found it. I'm sure. I think.
The first one I found is on the high pressure side. Good thing the recharge kit wouldn't fit. It would have 'sploded the refill can. Phew.
The low pressure side fitting is under a couple of parts that need to be removed and snuggled against another to make it very hard to get to. I hate working on this car.
without the aid of charging machine, it is easier to charge from the low side.
engine running and A/C "on".
there is a black sticker label somewhere that shows the right quantity (when empty).
if not empty, watch for the quantity via the "sight glass".
it is integrated on the filter/drier... on top of it.
