Brake Pad light
Old Jul 20, 2005 | 09:51 AM
kozmic's Avatar
Default Brake Pad light
My brake pad light indicator on a 2003 C230 Kompressor came on, and I changed the pads. I've put the indicator into the new pads, but the warning light still comes on when I start my auto up. Anyone have any info on how to clear this?
Old Jul 20, 2005 | 11:23 AM
sleepwalker's Avatar
Default RE: Brake Pad light
was it fitted properly and no open circuit?
please check the brake fluid level too if it's low.
maybe you got teo sensors... front and rear. check them both.
Old Jul 20, 2005 | 08:58 PM
MB/TECHMAN's Avatar
i seened pepole reuse there old sensors ,,big nono
Old Jul 21, 2005 | 01:32 AM
SL600_Cruzin's Avatar
Make sure you take into consideration what the two gentlemen before me stated as they are both correct.
What pads did you use ? Aftermarket or Dealer ??
All I have to add is.....
Double check everything.
Make certain the sensor is plugged in correctly.
The book shows that your vehicle has rear sensors as well, so the rear pads may be down to the sensors.
hope this helps
lipmana
Aug 21, 2007 11:31 PM
flintstone168
Mar 15, 2005 10:42 PM
tmazz
Dec 21, 2004 09:07 PM
purrplehaze
Dec 14, 2003 05:52 AM
yshaw
Nov 26, 2003 03:10 AM
