brake fluid in Ml 320 1999 cant find
RE: brake fluid in Ml 320 1999 cant find
Unless there's something weird about an ML, the fluid reservoir is on the driver's side, high up on the firewall. Look for a doughnut-shaped aluminum thingie about 12" diameter resting upright against the firewall. The reservoir is translucent and should be connected to the front center of it. There may be a "Fill" mark on the side or maybe a dipstick of some sort when you unscew the cap.
liquid_drop
08-08-2007 05:19 AM
