Bleeding Brakes Problem?
Old Jul 25, 2005 | 12:49 AM
dbenz's Avatar
Default Bleeding Brakes Problem?
I installed brand new brake pads and rotors. I tried bleeding the brakes and I cant get a constant flow of brake fluid to come through the rear calipers. I get a constant flow to come out for the front. Ive tried several different ways to bleed the brakes. But I mostly tried the one in the Haynes manual. Im not sure when the last time the brake fluid was changed. I say about 3-4 years ago. Could the lines be clogged up since the fluid hasnt been changed in so long? Or do I just have that much air in the lines? Could it be possible that the calipers are seized?
Also, what do you guys think about using the Motive Power Bleeder that Performance Products sells? Does it really work?
edhunt0r
May 7, 2014 06:56 PM
zdzich
Sep 17, 2009 11:21 AM
Zippy50
Apr 22, 2008 05:31 PM
inssane3gt
Sep 21, 2006 01:16 AM
greasepit
Aug 23, 2005 03:01 AM
