Auxiliary interior heater - How does it work?
Old 10-19-2004 | 12:30 PM
tobyd's Avatar
Default Auxiliary interior heater - How does it work?
I have bought an ex-Germany W124 500E that has the auxiliary pre-heater with the control panel just forward of the gear lever. It doesn't seem to work but no-one seems to have any info on it and the dealers stare blankly as they haven't seen one.I foundthis reference to the heater on an obscure web page that describes its operation but I need nore detail on the workings and parts.-
'The auxiliary heater (Zusatzheizung, code 228) is a separate heating
system that works independently of the engine. It consists of a
separate burner unit, an electric water pump, a control unit and it
is connected to the coolant circulation of the engine. It is run on
the fuel of the car (either diesel or petrol, these are different
units for obvious reasons) with a separate fuel line from the tank.
This makes it independent from an electrical outlet and from the
engine. It is started either manually, with a timer (mounted on the
center console or in the glovebox) or via a powerful FM-wireless
remote (the Mercedes units for from about 500 to 1000 metres
depending on local circumstances. The latest versions are available
with mobile phone remote control as well.
Once it is started, a spark plug ignites the burner which heats the
coolant up and the water pump recirculates the water through the
engine. The system heats the coolant up to 80°C and works until that
temperature is held in circulation. Once the temperature of 55°C is
achieved, a separate relay starts the heater blower and this heats up
the interior.
Even at very low temperatures in Alpine or Siberian regions, this
heats up the engine and the interior within 20-30 minutes. Apart from
a warm seat when you step in, the heat melts all snow and ice on the
windows without further ado.
Very comfortable and a must in Southern Germany, Switzerland and
Austria.
Many German Taxis have it as well since it helps them keep warm in
Winter when the wait and have no engine running.'
I still need some info to get mine working as well as instructions to work it, so if this rings a bell with anyone I'd love to know.
Toby.
Old 10-19-2004 | 06:17 PM
tobyd's Avatar
Default RE: Auxiliary interior heater - How does it work?
This is what the heater control looks like in the cabin.
[IMG]local://upfiles/3176/98C6206D1C4B46E482DEE85E9657D933.jpg[/IMG]
Old 10-20-2004 | 12:17 AM
sleepwalker's Avatar
so curious about the auxiliary heater?
[IMG]local://upfiles/1/51686F27117A49E582735D25687AB849.jpg[/IMG]
[IMG]local://upfiles/1/2CF3416E818D4E5EB2507EB9F36F8D69.jpg[/IMG]
Old 10-20-2004 | 05:46 AM
tobyd's Avatar
This is great thanks!!
Where did you get the info/pictures from? I hope that I can now find if the fuse or relays are faulty and get the thing working.
Cheers
Toby.
Old 10-20-2004 | 06:01 AM
i got them pictures from microfische that's why it is black coated.
remember that there is also a thermal fuse on the rear of the unit. check it only if it's not heating.
Old 10-20-2004 | 06:10 AM
tobyd's Avatar
Is it possible to get a copy of the microfische?
Old 10-20-2004 | 07:00 AM
i'm kidding, i'm kidding.
it was from mercedes-benz workshop information system or WIS.
everything was in there.
you can download it from Emule if you want.
you will need a license key to install it.
you can tell me your LAN ID and i will give you tthe license key.
Old 10-20-2004 | 07:12 AM
tobyd's Avatar
I'd like to download the WIS but I'm not sure what emule is!
Sorry to be a bit slow but can you hepl me out oh wise one!!
  #9
Old 10-20-2004 | 08:27 AM
Emule is a file sharing network or P2P (peer to peer).
you can download many things there such as movies, music and softwares.
WIS is compose of 5 ISO CD which i put there before (5/03 version).
you must have heard of kazaa or Edonkey or winmx?
  #10
Old 10-20-2004 | 02:51 PM
tobyd's Avatar
I have winmx. Can I get WIS through WinMx?
Quick Reply: Auxiliary interior heater - How does it work?
