Auto window up not working
I have a 2012 e350 and the automatic window close just stopped working. The window closes, I just have to hold the button up; and when it is up, it opens just a bit. Does anybody know what is the problem here and how to remedy this issue?
Had same problem with mine after the battery was disconnected , try using the key held very close to the sensor on the drivers door and lock the vehicle then unlock holding the key pressed , usually the windows will open ( may take a few seconds) then press to lock and hold! after windows should work normal i.e. open and close ! good luck!
patricknif
Mar 4, 2012 06:38 AM
slick1
Jul 30, 2007 07:05 PM
