air recirculator not working
i have a 1996 c200 the problem is the lights on the heater control keep flashing and if i try and turn on the a/r the red light keeps flashing. also if i dim the dash lights the miliage light and the time light flash at the same time. any help would be brill
The Heat/AC light(s) flashing is informing of a problem with HVAC system. Diagnostic codes can be read from the HVAC control panel that are quite good and can isolate just about any Heat or A/C problem. Do a diagnostic check of this system first.
Bill
Bill
Probably not. Heat not turning off could also mean, A/C not turning on. If the A/C compressor is correctly engaged (always on these cars, well mostly all the time), and you still have huge overheat, it could be the Mono/Duo valves. The control panel as last option. The valvesdo go bad as they work very hard all the time. They are expensive (several hundred dollars each). Use the diagnostics on the control panel to point you in the right path for repairs.
Bill.
Bill.
patricknif
03-04-2012 06:38 AM
