ABC problems
I just bought a 2003 CL55. I was not aware of the ABC issues. WHile sitting idle, the car lowers then raises back up. I want this fixed immediately. I hear this was a recall. What protion of the problem was a recall? Will mercedes still fix this issue or has the time frame closed?
Hey !! Repsonding to your message. The ABC problem is a pain. I ended paying 3 grand for a pump because the car lost all pressure and dropped to the ground. I got it fixed and it happened again. It ended up being a blocked valve in the rear strut. I would suggest taking it in ASAP. Don't wait until the message goes red telling you that you have to take the car in. there was a recall on a hose forthe ABC. Check with your dealership to see if it has been replaced . Good luck !
