95 S500 OVERHEATING
Old Sep 12, 2007 | 11:12 PM
SAMBO's Avatar
Default 95 S500 OVERHEATING
I need some help. I have a 1995 S500 with a over heating problem. After runnig for about 30 minutes, temp rises to one knoch below the red mark. Never rises to the red.
There is no coolant leak. I replace the thermostat and the212 degree switch. I still have the same problem.
Engine running with a/c on, the auxillary fan are not working. Can anyone tell me what they think is the problem
Old Sep 12, 2007 | 11:17 PM
SAMBO's Avatar
Default RE: 95 S500 OVERHEATING
98 MBZ S500 OVER HEATING
AUXILARY FANS NOT WORKING. FANS MOTOR ARE GOOD AND I REPLACE THE THERMOSTAT AND THE 212 DEGREE SWITCH. CAN ANYONE GIVE ME A SUGGESTION?
Old Sep 13, 2007 | 03:03 PM
fleegle's Avatar
check the cylinder compression or as a quick check look in the oil cap to see if there is any creamy white deposit its called emulsified oil it means you've blown one of the head gaskets. Or look for oil in the water tank.
RSNOWWIS
Jul 3, 2009 05:22 PM
arlo
Dec 14, 2008 05:55 PM
aazapf
Sep 5, 2006 10:34 AM
anotherlemon
May 16, 2004 01:53 PM
MaelVardyn
Nov 20, 2003 01:23 PM
