88 300E 3.0 GAS - HELP HELP HELP HELP
Old Aug 30, 2006 | 12:49 AM
w_white's Avatar
Default 88 300E 3.0 GAS - HELP HELP HELP HELP
I NEED HELP BAD,
My 300E has a gremlin. the car will run for a day or so, then it wont start. If I disconnect battery for a minute, then reconnect it will start fine. I just changed the fuel filter, cap & rotor. One issue that I need to fix is the neutral safety switch. The car will only start in neutral. The safety switch has been bad for a couple months. The starting issue just occured. Please help me I have 3 kids and with one car down its hard to get everyone where they need to go. P.S. All fuses look fine.
Old Aug 30, 2006 | 01:03 AM
kurt08's Avatar
Default RE: 88 300E 3.0 GAS - HELP HELP HELP HELP
try tapping your fuel pump relay
Old Aug 30, 2006 | 09:02 AM
wmercer's Avatar
Check the electrical connections to the fuel pump and the relay. Try cycling the key on and off a few times with a pause in between each cycle. See if you can determine if fule pump is turning on and off. Bill Mercer
MARIODRIVE
Nov 21, 2008 05:20 PM
kjtar
Jan 24, 2008 07:27 PM
fesgali
Sep 24, 2007 11:34 PM
cam69ss
Oct 25, 2004 02:45 PM
holdon007us
Feb 29, 2004 06:37 PM
