87 300SDL, help much appreciated.
Old Nov 3, 2004 | 06:19 AM
Teron's Avatar
Default 87 300SDL, help much appreciated.
New MB owner. 1987 300SDL 425k+ miles.
Sunroof is stuck shut, if standing on driver side, sunroof top is pressed down right rearmost side.
Easy to fix, known problem? What to look for/check?
Hazard switch area center dash is loose, needs some attention, how do you remove that center wood panel and the switches without breaking something?
Fuse box not helpful in regards to info, one is bad but no listing of amperage.
There is a short somewhere...drivers side door has been replaced due to theft damage. All drivers power doesn't work, passenger side only the power headrest works. Drivers side seat in lowest position making it difficult to drive vehicle.
Drivers side window off track, there is a long arm lever with a square block that slides in a track, after a half hour of trying to get it to line up I gave up. Motor works fine, it's just off it's track.
Brake line leaking in rear, what size brake line is required and ends?
Burnt wires (2) in trunk to trunk lid, repaired, no longer a problem.
Good source for a repair manual? Local auto stores say sold out can't order even for haynes.
Cautious of these $30 CD manuals on ebay, also cautious of the "official" $200 ones too.
Info much appreciated.
Teron
1973-220D
Dec 20, 2014 04:19 AM
cmgallag
Jan 12, 2009 01:19 PM
CKLASS1978
Jul 16, 2007 05:47 PM
2 Schaef
May 16, 2006 12:00 PM
CmyBenz
Oct 15, 2005 05:11 AM
