’86 MB 420 SEL Coolant Leak
Old 03-13-2004 | 08:56 PM
Randy's Avatar
Default ’86 MB 420 SEL Coolant Leak
Hi, my 420 must have a coolant leak, but I can't find it. After a 4-5 mile drive, steam and smoke comes from under the rear edge of the hood when I stop; open the hood and it is obvious this is coming from the exhaust crossover pipe which takes the exhaust from the driver's-side exhaust manifold, and the smell makes it obvious it is coolant. There is a rubber heater hose directly over the crossover pipe, with one of those "flush-and-fill" plastic fittings in it (is this stock?) but I simply cannot find anything leaking after looking really carefully several times, and feeling the underside of the hose with my hand, etc. So far I have not seen a sign of a drip on the garage floor, and the coolant level hasn't dropped noticably.</P>
I removed the computer and looked underneath at the hoses between the firewalls, and again I cannot see anything leaking nor any sign of previous leaks. The heater works fine. Please advise if you have experience with this, or ideas.</P>
Old 03-14-2004 | 02:08 PM
dave190e's Avatar
could be headgasket when the engine is running is there any bubbles in the coolent tank? is there steam comming out of the tail pipe? is there like a mayo looking stuff under the oil filler cap? all these point to head gasket.
Old 03-14-2004 | 06:22 PM
Randy's Avatar
Hi, I have none of the symptoms you described.</P>
</P>
Old 03-15-2004 | 01:36 AM
Randy's Avatar
Found the problem: someone installed a stupid "flush-and -fill" coonnection in the hose; 5/8 inch fittings are too loose for the metric hose, I think. I iwll try to find something to reconnect the two ends of the hose. Either it would stop leaking when hot, or at least i could not find the leak. When cold, the coolant would drip onto the exhaust crossover pipe and, when it get hot, steam and smoke!<IMG src=smileys/smiley1.gif border="0"></P>
</P>
Fine420SEL
09-08-2006 02:05 PM
Joe L
08-06-2005 02:55 AM
Randy
07-24-2004 07:43 PM
Randy
03-18-2004 12:53 AM
Randy
02-19-2004 03:13 AM
