85 300 CTD runs rough
Old Dec 1, 2009 | 02:40 PM
bomarhe's Avatar
Angry 85 300 CTD runs rough
Hi, I'm having a problem with a rough running engine. It rocks at idle in gear or out and has a harmonic rumble at higher RPMs. I have done the following: Replaced all fuel filters including the tank filters, diesel purge, adjusted valves, checked timing and timing chain, removed exhaust, removed and cleaned exhaust and intake manifolds, checked turbo, replaced all motor mounts, replaced injectors, did compression check (300 +-on test and balanced), pumped 100 PSI into combustion chamber with no leaks on intake or exhaust, replaced rack damper bolt, removed harmonic balancer, removed transmission amd flywheel, replaced torque convertor, cleaned banjo bolt and line, replaced primer pump, no vacuum leaks. I just don't know what else to do. I'm getting ready to replace the injection pump. Everything seems to be good with the head, but I'm leaning more in that direction. It sounds like a miss or a plugged exhaust. Kind of a chug-chug sound beginning at about 900 RPM. It's there at idle also, just not as noticeable, whole car rocks at idle.
Does anyone have any suggestions, perhaps someone else has had this problem and figured it out.
HELP!!!!
Bob
Old Dec 2, 2009 | 11:55 AM
scotts300tdt's Avatar
Have you checked air filter housing engine mount? The rubber bushings can strip from the bracket. Sometimes the bracket itself will fail at one point due to metal fatigue (vibration).
The air filter housing just bounces around on whats left. Just replaced my second one.
85 300tdt
manderson
Oct 22, 2008 07:06 PM
merkurmaniac
Mar 24, 2008 01:06 PM
Brisfer
Feb 29, 2008 11:18 AM
billsord
May 24, 2006 11:35 PM
blurp
Jul 17, 2004 12:57 PM
