67 250S not starting.
It's getting fuel, all the grounds are good, new plugs, new wires (all on properly), new rotor, new cap, firing order is correct, all the fuses and relays are good, new ignition coil, still no start.
I noticed that there's fuel starting to pool around the carburetor that's next to the firewall. I don't know if that's a bad sign or not.
It cranks but it's still seeming like there's no spark. Any help?
I've narrowed it down to something between the ignition coil and the ignition. The coil itself isn't getting enough power to it. What could possibly be between those two that's causing lack of power to the ignition coil?
babybottombenz
06-13-2005 12:17 PM
