450 SL fuel problem
Old Aug 22, 2014 | 08:56 PM
belair's Avatar
Default 450 SL fuel problem
Just got a 78 450SL with problems. It set outside for a few years. I have cleaned the gas tank put on new filters and pump flushed all the lines and cleaned the injectors. will start and run for a second and cut off. running very rich. at one point #4 and#8 cylinder filled with gas and engine would not turn over. What to do next. Any help appreciated.
Old Sep 8, 2014 | 06:22 PM
franzfer's Avatar
I owned a 1975 450 SLC with the same problem. I remember that he changed an electronic module, but it was many years ago and I have no other information.
Old Sep 9, 2014 | 07:01 PM
belair's Avatar
Thanks for the reply. Have educated myself a lot in the last month. I have a bad cold start valve and not enough fuel pressure to open injectors. Also need new fuel distributor pressure valve. I will get it going. Will just take money and time. Thanks again.
Old Mar 28, 2015 | 04:03 PM
franzfer's Avatar
The theme is old, but can be useful the Mercedes Benz Service Manual V-8 Engines M 116 (3.5), M 117 (4.5).
Regards!
Old Mar 29, 2015 | 08:06 AM
belair's Avatar
Thanks for the info. I have that manual and it has helped with several problems. I just need to spend more time on it.
sheaflite
Jun 16, 2011 11:37 AM
LostViet408
Mar 1, 2011 10:03 PM
hapaschold
Oct 5, 2007 05:59 PM
nxk2000
Jan 21, 2007 10:17 PM
ggp53
Aug 23, 2005 12:51 AM
