380SL won't start in the rain
Old Jan 16, 2011 | 01:40 PM
carolparsons's Avatar
Smile 380SL won't start in the rain
When it's raining, this car won't start. the battery is new. It cranks strong but takes 5-10 tries and it starts rough and will stall out if you give it gas or shift until it warms up. Runs fine in any other weather. This is very inconvenient since I moved to Oregon. It rains here a LOT!
Old Jan 16, 2011 | 03:10 PM
2slowcdi's Avatar
Years ago I had a truck that would do the same thing.
Everything checked out, this went on for two years "not as wet in Texas"
then my alternator went out and after replacing it everything was good after that.
The bad thing was the alternator had checked out good.
You could try the air can that you clean your key board with and try to dry the alternator out one time when it is acting up, to see if it works.
Good luck.
Old Jan 16, 2011 | 03:17 PM
chassis221's Avatar
i would guess cap and rotor and new wires. at night time with the engine running using a water bottle, spray water onto the wires and cap and check for spark jumping.
Old Jan 16, 2011 | 03:45 PM
smat2hews's Avatar
Default Moisture in the distributor cap?
Did you check? That would be the first thing I would look at...
spoiled_amy
Sep 12, 2024 11:45 AM
ftby59
Aug 21, 2020 12:24 PM
Marv t
Jan 18, 2015 01:53 PM
thenetters21
Mar 7, 2012 10:14 AM
wicked.ludicrous
Jul 13, 2011 08:20 AM
