300 SE RIGHT INDICATOR
problems problems problems! im soo fed up ! can any 1 be able to help me with this 1 ?... problems come out of the blue!... my mercedes 300SE 1989 w126 series's the turn signal to the left functions correctly at a natrual pace!, but when i push the turn signal rod to the right.... the turn signal light starts flickering faster than it normal would at a fast pace.ive noticed since it does this , the front turn signal lamp flashs fast but the rear right turn signal light does`nt flash at all .!
i ve check the fuse under neath the bonnet..all the fuses are in tact. any idea what it can be ?![Frown](https://mercedesforum.com/forum/images/smilies/frown.gif)
yea i checked the rear signal bulb , the metal ligment is all in one peice, but however the problem is the right turn signal flashes more faster than it wud normally do,the front right signal flashes fast but the right rear does not, cud there be anything else wrong ? any suggestions ideas ?
The rapid flash in the front is telling you that you have a problem in the rear. Check the rear bulb and also the rear contact. When you get the rear working, the front will go back to the normal flash rate.
