260e troubleshooting
Old Aug 5, 2006 | 07:11 PM
jetdoc's Avatar
Default 260e troubleshooting
I have several issues for you experts out there. #1) The fuel gauge indicator is acting erratic as I drive. Does any one have the electrical schematic for the fuel indicator system?
#2) It's very hot here in Kansas and the A/C is blowing cold out the dash vents and HOT out the over dash (defrost) vents. HELP!
#3) I am in need of a PDF of the owners manual, but http://www.mbusa.com/owners/vehicle_...ers_manual.jsp says that mine is not available from their sight. can any one help with this one?
Thanks in advance!
Jetdoc.
Old Aug 11, 2006 | 08:54 AM
jetdoc's Avatar
Default RE: 260e troubleshooting
OK, its been 5 HOT days and I have had no reply! I was hoping to have some guidance by Saturday as it is my day off and the only chance I have to work on these problems in the early morning, before we get baked. Seems sad, 18 hits but 0 replys.
Old Aug 11, 2006 | 10:44 AM
jmang09's Avatar
what year 260? I might have a manual for you.
j-mang
Old Aug 11, 2006 | 07:00 PM
jetdoc's Avatar
it's a 1989 260E (I should have put that in in the 1st place)
Old Aug 11, 2006 | 08:19 PM
BlueSilver's Avatar
Jetdoc.
More than one under dash problem? Not a clue, but I'll try to help find a manual on the car.
Charles
Old Aug 12, 2006 | 08:41 PM
jetdoc's Avatar
as an addendum to the HOT air from the windshield vents, I did some troubleshooting today and found that the solenoid (water shut off) valve, (next to the battery) seams to be functioning correctly, (extended to block water when powered). So how else can the hot water be passing thru?
Old Mar 24, 2010 | 01:39 PM
knobbycva's Avatar
Default AC/heat
solenoid (water shut off) disconnect wires to it and disconnect the AUX water pump on passenger side wheel well then see if that cures your problem but I think it will be the climate control unit get one at a scrap yard find a late model one
Kpassa
Jul 22, 2009 02:23 PM
viperzone
Nov 4, 2008 01:25 PM
hugoestr
Oct 8, 2006 07:27 PM
michaeld
Jul 4, 2006 06:19 PM
jmsbiz
Sep 23, 2005 11:33 AM
