2002 S 430 is stuck in park PLEASE HELP!!!
Old 06-06-2007 | 11:38 PM
James1340's Avatar
Default 2002 S 430 is stuck in park PLEASE HELP!!!
I have A big problem on a 2002 mercedes S430 that I am working on for my friend.His wife drove to to work,everything was fine...She get's into the car after work,and it will not come out of park!She called the Dealer,and they said that there is not any by-pass for the shift interlock.I found this impossible,since every other time I have had this problem on other cars,there has always been a BY-PASS,so I look at car,owners manual,and talk to the dealers service dept(No BY-PASS)I use ALL-DATA software,so I call them,No information for interlock,And I did check the brake lights-working fine.HELP!! Does anyone know how to test or repair,or a wiring diagram,or a diagnosis chart how to test and repair? Please HELP ME!! thank's Jim
Old 06-07-2007 | 09:12 PM
sleepwalker's Avatar
Default RE: 2002 S 430 is stuck in park PLEASE HELP!!!
no bypass on S-Class. E-class and C-Class, yes.
the ESM is faulty. (electronic shift module). replace it.
however to bypass it so you can drive, remove the 4 screws that holds the ESM and remove the locking pin solenoid.
Old 06-10-2007 | 12:11 AM
startech's Avatar
remove the shift **** and hit the shifter with a hammer (hard)while pulling it into gear or remove shifter cover and hit the right rear corner of the shifter with a hammer/punch. E and C class have a black lever when you remove the shift cover.
Old 06-22-2007 | 09:58 AM
msblueS52U's Avatar
so what did they end up doing and how much did it cost to repair because I am having the same problem with the 02 S500
Old 06-22-2007 | 10:00 AM
msblueS52U's Avatar
and how much does this cost?
Old 10-26-2008 | 02:14 AM
bigbaby's Avatar
How do you remove the shift **** and do i have to remove the center console to get to the esm
foto1
12-15-2014 10:58 AM
starchild
04-29-2014 12:55 AM
antx227
05-05-2013 10:11 PM
SLKLUVR
05-28-2008 06:40 AM
Quick Reply: 2002 S 430 is stuck in park PLEASE HELP!!!
