1995 SL600 ADS, Battery ??
I recently had to change the battery in my 1995 SL600 (21000 original miles). After changing the battery I noticed that the front of the car was only 4 inches off the ground. Unfortunately I did not notice if this was the case before I changed the battery. The old battery was completely dead. In any event, I have checked the ADS reservoir, checked for leaks, etc..etc.. everything appears normal. I have cycled the ADS switch with the car running and the light on the ADS switch toggles on and off (I believe this is normal)... There are no warning lights illuminated on the dash panel. The car runs fine otherwise... How do I remedy the front suspension height problem ? Is there something i need to do to re-initialize the electronics after changing out the battery ?? or ????
