1988 190E Trun Signals Don't work
Old Jun 3, 2006 | 10:36 PM
hoytheld's Avatar
Default 1988 190E Trun Signals Don't work
When I actuate the turn signal arm either way, the interior arrows do not light up and there is no action on the outside of the car. Fuse is ok because the horn works...on the same circuit. Could it be the signal "flasher pot" I don't know the real name...the thing that typically looks like a little metal canister? If so...where is it located?
Old Jun 4, 2006 | 12:38 AM
hoytheld's Avatar
Default RE: 1988 190E Trun Signals Don't work
Git it!! Hazzard switch was stuck between off and on...yeee hawww!!!
Old Jun 4, 2006 | 11:01 PM
danny J's Avatar
just out of interest thats the same arm that the window wiper is on right? also is your heated rear window button on the dash left of the wheel? and is it a rocker switch or a click switch?
Old Jun 5, 2006 | 05:19 AM
dbenz's Avatar
ORIGINAL: hoytheld
Thats a common problem for these cars. Sometimes they freeze up and some electrical contact cleaner might help.
Old Jun 5, 2006 | 07:35 AM
danny J's Avatar
excelent i give it a go, thanks
Old Aug 19, 2012 | 12:19 PM
DickRMurphy's Avatar
Ditto. Thanks for the post. My daughter had borrowed my wife's car and it came back with turn signals not working after 20 miles on a bumpy dirt road. I checked out all the fuses, the combo relay, etc. The hazard switch had apparently been bumped a bit. That was perhaps the easiest repair I've ever done. Switch on, switch off, everything works.
brockway
Dec 13, 2006 12:44 PM
no clue
Jul 1, 2006 04:12 AM
nach23
Mar 31, 2006 02:29 PM
Sphil98clk320
Nov 26, 2004 08:43 PM
83scrambler
Nov 21, 2004 09:59 PM
