1986 260e rear wheel bearings?
Can anyone help with this one.Rear wheel has play in it.I jacked it up and found i could move wheel from side to side when held in hands.There is no noise coming from wheel when driving.I only noticed when i felt car wobble a bit.Any help would be appriciated.Thanks
RE: 1986 260e rear wheel bearings?
that depends on where the movement is as you see.
Hi, movement is when i hold wheel it wobbles from somewhere behind wheel ,it seems to be at the end of driveshaft
can it be any rubber bushings?
if on the front wheel i would readily agree with you that it is the wheel bearing. the rear wheel bearing will create a humming sound if bad. |
I had not thought of that.Is it a big job?I hope not
replacing rear wheel bearing? it's a big job. front ones are easy.
you checked you link bushings ..they got like 5 links..i hate doing rear bearings sleepwalker..[:@]
I,ve not had time to check yet ,as soon as i can i will.Thanks for the advice,i will let you know how i got on.You have both been very helpfull .Thanks again
