1986 260e rear wheel bearings?
Old Jun 18, 2005 | 11:28 AM
don's Avatar
don
Default 1986 260e rear wheel bearings?
Can anyone help with this one.Rear wheel has play in it.I jacked it up and found i could move wheel from side to side when held in hands.There is no noise coming from wheel when driving.I only noticed when i felt car wobble a bit.Any help would be appriciated.Thanks
Old Jun 18, 2005 | 01:51 PM
sleepwalker's Avatar
Default RE: 1986 260e rear wheel bearings?
that depends on where the movement is as you see.
Old Jun 19, 2005 | 04:42 AM
don's Avatar
don
Hi, movement is when i hold wheel it wobbles from somewhere behind wheel ,it seems to be at the end of driveshaft
Old Jun 19, 2005 | 05:57 AM
can it be any rubber bushings?
if on the front wheel i would readily agree with you that it is the wheel bearing.
the rear wheel bearing will create a humming sound if bad.
Old Jun 19, 2005 | 09:18 AM
don's Avatar
don
I had not thought of that.Is it a big job?I hope not
Old Jun 19, 2005 | 12:05 PM
replacing rear wheel bearing? it's a big job. front ones are easy.
Old Jun 19, 2005 | 03:56 PM
MB/TECHMAN's Avatar
you checked you link bushings ..they got like 5 links..i hate doing rear bearings sleepwalker..[:@]
Old Jun 22, 2005 | 08:34 AM
don's Avatar
don
I,ve not had time to check yet ,as soon as i can i will.Thanks for the advice,i will let you know how i got on.You have both been very helpfull .Thanks again
mbenz80
Apr 21, 2009 10:30 PM
hawaiianbio
Oct 9, 2008 01:58 AM
Schnezza
Aug 18, 2008 08:41 PM
CLK_Sous
Sep 8, 2005 12:40 AM
bbob
Feb 4, 2005 10:32 PM
