104.980 part identification
Old Nov 21, 2010 | 04:01 PM
mattsltd's Avatar
Default 104.980 part identification
I need help identifying a part. I have a '90 300ce. I made the grave mistake of allowing an alleged mechanic do some simple engine work that resulted in some serious engine damage. After a lengthy period of time, and it never getting fixed, I had to remove my vehicle from his shop, along with a number of boxes of parts. I have a part that at first sight looks like a wood-ruff key, but with an end ground off and a notch on the flat side. I think that it must ratchet or index in operation. I do not know if it is associated with the timing chain tensioner. I can not find it in my manual or online. The approximate size is 10mm long, 5mm tall, 5mm thick. I can almost complete assembly and see no where this part should be. Also, there is a possibility, this fell into the box in his shop and is not related. But, I doubt it, and would be foolish to not seek help.
Old Nov 25, 2010 | 10:48 AM
waybomb's Avatar
If you have a credit card with a US address on it, you can access Mercedes EPC here:
http://epc.startekinfo.com/epc/login.jsp
You can then look up your engine and find where this woodruff key may have came from.
Old Nov 26, 2010 | 03:01 PM
mattsltd's Avatar
This has not been subject to any 'hammer'. There are no impact marks. All sides still have casting/machining marks without dents, nicks or scratches. The flat side, at the tapered end, has slight abrasion marks from where it makes contact when it is in place. The notch/groove is perfectly symmetrical, shaped and positioned, it resembles the sears and pawls on parts that I would see on parts while doing gunsmith work. I have lined it up with the wood-ruff key that I have on the crankshaft and it exactly identical, except the flat end and the notch. This was formed by a shear or a shearing action. This has to be an intentional and deliberate part. I cannot believe this was caused by failure or an inept mechanic. It is too perfect. And, if a 'mechanic' caused this, at least one other part would be showing signs of force. I have attached another angle of view, and, I could provide some pictures, taken with my macro lens, that can show a more clear view.
Attached Thumbnails 104.980 part identification-dsc_0255.jpg   104.980 part identification-dsc_0254.jpg
Last edited by mattsltd; Nov 26, 2010 at 03:04 PM. Reason: proper grammar/punctuation
Borgli
Nov 3, 2013 02:52 PM
Borgli
Oct 29, 2013 04:27 PM
benzrookie
Nov 28, 2008 01:41 PM
opentech
Nov 6, 2005 02:43 AM
JLHowie
Sep 9, 2005 12:18 AM
