Suspension Kits?
#12
No, don't do that. They're designed to be used without grease. Grease will lessen their performance. Think of trying to control something with your hands that twists and shifts and has grease on it. It's rigid tension from a dry bushing that improves handling. Grease reduces that tension considerably. It will also attract dirt which will shorten their life.
#14
Yeah, sort of, in a way. That's the easiest way to explain it.
The poly bushing are much harder than stock. They don't "give" like stock. They maintain a stiffness at the links. The "mushiness" of the stock suspension is eliminated. Grease just works against all that. Plus, certain greases may cause them to deteriorate.
#17
ORIGINAL: Lugnut
You need to check high-performance suspension specialists. However, poly bushing aren't available for every car.
#18
I bought H&R lowering spings. Which drop it 1.5 inches. I could fit 2 fingers between the fender and the wheel and 1 finger in the back. I recommend to buy aftermarket ajustable shocks, though. I thought the dampening was to soft on the stock shocks. Overall there great springs, you'll be satified with the ride.
