HID replacement for 350SD?
I want to know if it's possible to replace stock headlights and / or fog lights with HID for 91' 350SD. Questions: - What on-line retailers supply reliable HID replacement? - Would the replacement fit perfectly or would they require body/harness mods? - What mods to electrical system (e.g., fuses) are required to do this? - In NJ, where I live, 'blue lights' are not legal, so what color temp (Kelvin) HID lamps should be used? I was told some where around 4300K - is that right? Bottom line: Is this a DIY job? I am handy, but I might not have all the tools ... Thank you. |
RE: HID replacement for 350SD?
ORIGINAL: zanybrainy I want to know if it's possible to replace stock headlights and / or fog lights with HID for 91' 350SD. Questions: - What on-line retailers supply reliable HID replacement? - Would the replacement fit perfectly or would they require body/harness mods? - What mods to electrical system (e.g., fuses) are required to do this? - In NJ, where I live, 'blue lights' are not legal, so what color temp (Kelvin) HID lamps should be used? I was told some where around 4300K - is that right? Bottom line: Is this a DIY job? I am handy, but I might not have all the tools ... Thank you. there´s no Xenon designed to be for Your vehicle. Re-fitting is maybe possible but I don´t know, if it is allowed in Your country without automatically heith adjustment and head light cleaning device. There are already a couple of threads here about this topic... already tried? Yes, the light colour between 4100 and 4900 is more white. The higher the light temperatur is, the more it get´s to blue, like for example about 8000K regards Peter |
We have high quality HID kits available. We also have 4300K bulbs that are more white than blue.
