Vacuum Pump repair.
Last weekend I dug all the way down to the vacuum pump, got it apart, and realized that the repair kit I bought was the wrong one (small gasket needed instead of disk). So I had to put it all back together, and now my brake pedal is rock hard. I have to stand on it to get decent braking power. When I took the cover off the vacuum pump, the little round disk that goes in the hole running to the brake booster line fell out. I put it back in on reassembly, and it looked like I put it in correctly, but I am sure something isnt right. I am going to have to get the new kit obviously, but what do I need to do to get the brake working right again?
Thanks in advance. |
vacuum,...the power brakes work off the vacuum your vac pump is creating.no vacuum means no power assist so you need muscle.
