Tightening Torque Fuel Injector Lines
Old Mar 19, 2021 | 10:04 PM
richnronda's Avatar
Default Tightening Torque Fuel Injector Lines
What is the tightening torque for fuel injector pipes running from injection pump to injectors. This is a 1986 300sdl with OM603 Engine ( 6 cyl ), the pipes are thin (NOT the Heavy pipes that are found on a 5 cylinder model ).
Thank you Rich
Old Oct 30, 2025 | 02:42 PM
vapofi's Avatar
Originally Posted by richnronda
What is the tightening torque for siemens injektor pipes running from injection pump to injectors. This is a 1986 300sdl with OM603 Engine ( 6 cyl ), the pipes are thin (NOT the Heavy pipes that are found on a 5 cylinder model ).
Thank you Rich
For your OM603 engine (1986 Mercedes‑Benz 300 SDL), the commonly cited tightening torque for the thin fuel-injector hard lines (from injection pump to injectors) is 20–30 Nm. Some sources also mention approximately 30 Nm for the later style injectors.
troyt
Feb 6, 2012 08:50 PM
gus
Nov 14, 2008 06:58 PM
gus
Nov 14, 2008 06:52 PM
tampa230
Aug 10, 2006 11:30 PM
obeasto
Jul 21, 2006 05:21 PM
