SIGNAL LIGHT STOP WORKING!!!!
I need help, my signal light stop blinking in my Mbz 82 300TD, the lights are on but don't blink anymore, I check the fuse they seems ok...Does
anyone knows what could be the problem....and if it's the relay!!! Where is it located??? Thanks
I had a similar problem. The fuse will LOOK fine but the fact is that the ends are corroded (really not noticable unless you pull it out and look closely). So the solution is either off-center the fuse so that it gets good contact or simply replace it.
ijdetoro
Feb 26, 2010 01:15 PM
gododiroma
Feb 21, 2009 09:27 AM
MITCHELL
May 4, 2008 09:50 PM
