Rear Diff Fluid Change
Old Jan 14, 2007 | 06:56 AM
Its_Puddin!'s Avatar
Default Rear Diff Fluid Change
How many miles should I go before changing the rear diff fluid?
Old Jan 14, 2007 | 04:33 PM
Charles Munn's Avatar
Default RE: Rear Diff Fluid Change
ORIGINAL: Its_Puddin!
What is the year, make, model and number of miles on the OD? How long have you owned it? Doesthe log indicate it's ever been changed? Did you routinely change it when you bought the car, along with all of the other fluids?
Old Jan 15, 2007 | 12:19 AM
I have a 78' 300D. It has 164k. I have owned it for 2 years and have put about 40k on it. I have not done it since I have owned it.
Old Jan 15, 2007 | 09:08 PM
affalterbach65's Avatar
chances are the previous owner didnt do it either, unless it was maintained at a dealer for the life of the car and had every recommended maintenance done and no penny spared.
whether or not it is nessecary to change it is hard to say without seeing the car and checking the fluid condition, but i certainly wouldnt hurt the vehicle to do it, as long as its done right.
Old Jan 16, 2007 | 06:39 AM
otm646's Avatar
remember to clean every thing off to keep the grubby stuff out. secondly try the upper "fill" plug first. if you drain the contents you will have a fun night ahead of you if you can't remove the fill plug as well. my drain plug on my 76' 300d was froze up but that did not matter i got a large syringe, you can get them at auto parts stores or a medical supply house, and a length of tubing and just suctioned out the old contents and refilled with the suitable lubricant.
Old Jan 17, 2007 | 06:22 AM
I read on dieselgiant about that and making sure to do the top first.
Old Jan 17, 2007 | 02:40 PM
When buying a used car, unless I have a log that showswhen filters and fluids have been done, I automatically replace all fluids and filters, including the differential.That said,IMHO, your differential fluid change is long over due.
Old May 27, 2010 | 12:50 PM
cjbrown's Avatar
I agree on fluid changes. I just picked up a 79 240 with manual trans and looking for diff and gearbox fluid recommendations.
ATF for the gearbox?
Synthetic diff fluid, 75w-90 or 75w-110
I use amsoil synthetics in everything, any reason not to use them here?
Thank you! First post...
Old May 27, 2010 | 07:09 PM
  #9
Diesel9112's Avatar
That comment about checking the Fluid levels after you buy a Car is extremely true. Many People do not even know the Differential Fluid/Oil needs to cecked let alone changes.
In the Old days when you got your Suspension,U-Joints and Chassie greased they also checked the Manual Transmission and Differential Oil levels.
Now the Suspension, Chassie and sometimes even the U-Joints cannot be re-greased so checking the Manual Trans and Differential Oil has fallen by the way side unless the Car Owner ask for them to be checked.
Old Dec 2, 2023 | 10:48 AM
  #10
sjulier@gmail.com's Avatar
1992 300D 2.5 turbo; Automatic, standard differential
ATF: Liqui-Moly Top Tec 1100
Differential: Liqui-Moly 85W90 GL-5
Power Steering: Febi 08972
All meet the applicable MB specifications
mtbt6874
Aug 30, 2011 07:33 PM
abeaulieu06
Apr 12, 2010 09:07 PM
jinsoojoo
Oct 7, 2005 10:36 AM
Buck
Aug 10, 2004 09:30 PM
cmscott16
Jan 1, 2004 02:19 PM
