Power Steering Fluid, special or not?
The 85 300sd I will be getting is doing some "groaning" around the driver's side wheel when turning and sometimes straight. I noticed the power steering was fluid was a little low. Does it use some special euro formula or is it just normal power steering fluid? I would appreciatie any help.
OK, two people need answers..........First, realize that there is a filter within the power steering pump.....should replace......second, DO NOT put automatic transmission fluid back in as replacement..(older MB's are sensitive) (plays with seals) use only -power steering fluid- as bought in auto parts stores, or go to the dealer!
Change your brake fluid too.............every other year......ya!
if you remove the fluid in the pump reservoir by any means available to you the filter is at the bottom. usually held by a press nut or a regular threaded nut.
